About CE4 CE5 and INT6's pin asisgnment in FPGA
Added by Haibo Pang over 11 years ago
I want to design a sync fifo in the FPGA, which will use a synchronous interface in EMIF. So it is better
to use a separate CE pin other than CE2.
According to the MityDspProSpec.pdf, DSP pins CE2 CE4 CE5 INT4 INT5 INT6 are connected to the FPGA.
From the MityDsp-pro.ucf we knew that CE2 INT4 and INT5 are connected. But for CE4 CE5 and INT6,
are they connected? If They are,wich FPGA pins are they connected to?
Haibo Pang
RE: About CE4 CE5 and INT6's pin asisgnment in FPGA - Added by Michael Williamson over 11 years ago
Hello.
CE4 is connected to W15 of the FPGA (Bank 4).
CE5 is connected to AA15 of the FPGA (Bank 4).
GP [6] is connected to the FPGA_INIT_B signal on the FPGA, AC14. There is also an external 1K pullup to 3.3V on this net.
GP [7] is connected to the FPGA_DONE signal on the FPGA, AC24. There is also a 1K pullup and a 1K/diode net connected to this net.
