How does DSP configure FPGA program?
Added by 锋 曲 about 12 years ago
I'm using MityDSP-PRO Development Kit to our project, and our DSP is 6455,and FPGA is xc3s4000. I want to know how does DSP configure FPGA program? Does it is the way of picture attached? if so, would you like to tell us the related IOs information in DSP, thank you.
Qu Feng
Replies (4)
RE: How does DSP configure FPGA program? - Added by Michael Williamson about 12 years ago
The DSP configures the FPGA using slave parallel select mode (8-bits at a time) using a connection to the EMIFA and a couple of GPIO pins to drive the PROGRAM, CS, and INIT pins to monitor the load status.
Details about parallel slave select mode are in the Xilinx Spartan Family configuration guide on the Xilinx website.
RE: How does DSP configure FPGA program? - Added by 锋 曲 about 12 years ago
Hello mike,
Thank you very much for your reply, I would like to know which pins of DSP are used to configure FPGA, like CCLK,WRITE,DATA[0:7],BUSY,,DONE,INIT,PROGRAM. Because the program framework of our project has been completed, and the time does not allow us to modify framework according to your company, so if we know which pins of DSP are used to configure the FPGA, and then we just modify a little DSP program to complete application. So would you like to provide the IO port information or this part of the schematic, thank you very much.
Qu Feng
Here you go. Good luck.
FPGA DSP
DONE GP_7
INIT GP_6
PROGRAM GP_1
CCLK EMIF_AAOEn and EMIF_AAWEn (external and gate)
BUSY EMIF_AARDY
D(7..0) EMIF_AED(7..0)
CS EMIF_ACE2n and EMIF_ACE3n (external and gate)
WRITEn tied low
Thank you very much Mike,
    (1-4/4)
