MitySOM-AM57X Texas Instruments AM57XX SOC Wiki Page¶
- MitySOM-AM57X Texas Instruments AM57XX SOC Wiki Page
- Repositories
- Development Kit
- Software
- FPGA / VHDL
- Multi-Core Support
- Hardware Design
- Frequently Asked Questions
- Reference Material
- Recent Updates:
Support is included for the MitySOM-AM57X. See The Critical Link website for top level summaries of this platform.
- MitySOM-AM57X DataSheet [pdf]
- MitySOM-AM57X Dev Board DataSheet [pdf]: Please contact Critical Link
- MitySOM-AM57X Carrier Board Design Guide: Please contact Critical Link
Errata and Product Change Notifications for the MitySOM-AM57X can be found in the Hardware Design section of this wiki.
Repositories¶
The following are links to the repositories that Critical Link provides for the kernel, U-Boot, Yocto, and FPGA sample project.
| Type | Repo | Branch |
| Kernel | https://support.criticallink.com/gitweb/?p=processor-sdk-linux.git;a=summary | mitysom-linux-4.19 |
| U-Boot | https://support.criticallink.com/gitweb/?p=processor-sdk-u-boot.git;a=summary | processor-sdk-u-boot-2019.01 |
| Yocto Layer | https://support.criticallink.com/gitweb/?p=meta-mitysom.git;a=summary | thud |
| Example FPGA Projects | https://support.criticallink.com/gitweb/?p=mitysom-am57x-ref.git;a=summary | main |
Development Kit¶
Pre-Built Images¶
The following is a link to pre-built binaries for the development SD card image for the SOM variants. This will work with the FPGA or non-FPGA variants. It includes the preloader, uboot, and root filesystem.
Note: SD-Card Image requires a 16GB+ sd card.
| Description | Location |
| Reference Micro-SD card Image | tisdk-rootfs-image |
| Reference Linux Developer Toolchain (based on TI's AM57xx PROCESSOR-SDK-LINUX) | arago-2019.11-armv7a-linux-gnueabi-tisdk.sh |
For flashing the Micro-SD card, we recommend using balenaEtcher .
Build Flow¶
- Docker build environment
- U-Boot Building for MitySOM-AM57X
- Building the Yocto Root Filesystem for MitySOM-AM57X
- Building the Linux Kernel for MitySOM-AM57X
- Building Vivado Example Projects for MitySOM-AM57X
- Building DSP Example Projects
Software¶
U-Boot¶
Linux Operating System¶
FPGA / VHDL¶
Multi-Core Support¶
Hardware Design¶
- Errata and Module Product Change Notifications
- Power Supply and Heat Dissipation
- Mounting Hole Locations
- Shock and Vibration
- Hardware Design Guidelines
- CAD Files and Information
- Clearance Beneath Module
- On-Module Trace Lengths
- MXM Connector Information
- Setup Pinmux
- MitySOM-AM57X Pin-Out Spreadsheet
Frequently Asked Questions¶
Reference Material¶
A large portion of the software has been developed using information from the sites listed below:
Recent Updates:¶
Updated almost 2 years ago by John Pruitt
