Repositories and Pre-built Images¶
Source Code Repositories¶
The following are links to the repositories that Critical Link provides for the kernel, U-Boot, Yocto, and FPGA sample projects.
- SDK 6.03
Type Repo Branch Kernel https://support.criticallink.com/gitweb/?p=processor-sdk-linux.git;a=summary mitysom-linux-4.19U-Boot https://support.criticallink.com/gitweb/?p=processor-sdk-u-boot.git;a=summary processor-sdk-u-boot-2019.01Yocto Layer https://support.criticallink.com/gitweb/?p=meta-mitysom.git;a=summary thudExample FPGA Projects https://support.criticallink.com/gitweb/?p=mitysom-am57x-ref.git;a=summary main
- SDK 9.03
Kernel https://support.criticallink.com/gitweb/?p=linux-ti.git mitysom-linux-6.1.yU-Boot https://support.criticallink.com/gitweb/?p=u-boot-ti.git mitysom-u-boot-2023.04Yocto Layer https://support.criticallink.com/gitweb/?p=meta-mitysom.git kirkstoneExample FPGA Projects https://support.criticallink.com/gitweb/?p=mitysom-am57x-ref.git;a=summary main
Pre-Built Images for the Development Kit¶
The following is a link to pre-built binaries for the development SD card image for the SOM variants. This will work with the FPGA or non-FPGA variants. It includes the preloader, uboot, and root filesystem.
- SDK 6.03
Description Location Manifest Based on TI Release Toolchain Reference Micro-SD card Image tisdk-rootfs-image-mitysom-am57x-20210909.rootfs.img.zip md5 06.03.00.106 gcc version 8.3 2019.03 hard-float
- SDK 9.03
Description Location Manifest Based on TI Release Toolchain Release Notes Reference Micro-SD card Image tisdk-base-image-mitysom-am57x-20250812184753.rootfs-SDK09.03.06.05_2.img.zip md5 Manifest 09.03.06.05 gcc version 11.4 Release Notes tisdk-default-image-mitysom-am57x-20250812190611.rootfs-SDK09.03.06.05_2.img.zip md5 Manifest
Note: The SD-Card Image requires a 16GB+ sd card.
For flashing the Micro-SD card, we recommend using balenaEtcher. As it will handle unzipping and checking the md5sum for you.
Reference Toolchain Image¶
The following is a link to the Reference Linux Developer Toolchain based on TI's AM57xx PROCESSOR-SDK-LINUX)
- SDK 6.03
Description Location Reference Linux Developer Toolchain arago-2019.11-armv7a-linux-gnueabi-tisdk.sh md5
- SDK 9.03
Description Location Manifest Reference Linux Developer Toolchain arago-2023.10-armv7a-linux-gnueabi-tisdk-mitysom-am57x-SDK09.03.06.05_2-20250812190611.sh md5 Manifest
