Building U-Boot for MitySOM-AM57X¶
- Building U-Boot for MitySOM-AM57X
Before you begin¶
There are multiple ways to customize and compile the U-Boot for your project. Please try to build U-Boot as-is with no changes before you try to add your customizations. This will ensure your environment and toolchain are setup correctly.
- ARM toolchain - You can use a previously compiled ARM toolchain provided by ARM.
- Yocto Environment - If you are using the docker environment and Yocto for your filesystem, you can use its tools to customize and build U-Boot.
In most cases, you will use one of the first two options for initial bring-up and testing. Then, once you have everything working you can integrate your custom code into Yocto.
Critical Link U-Boot Repository¶
Critical Link recommends using the processor-sdk-u-boot-2019.01 branch on our git server: https://support.criticallink.com/gitweb/?p=processor-sdk-u-boot.git;a=summary.
Other MitySOM-AM57x U-Boot branches seen on the repository should not be considered stable, and are used for internal feature development.
U-Boot Build - ARM toolchain¶
Configuring the Build Environment¶
Download the ARM toolchain and setup the build environment using the following commands:
mkdir -p /home/tools/mitysom-57x wget https://developer.arm.com/-/media/Files/downloads/gnu-a/8.3-2019.03/binrel/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf.tar.xz -O - | tar -Jxv -C /home/tools/mitysom-57x/ export TOOLCHAIN_PATH_ARMV7=/home/tools/mitysom-57x/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf export ARCH=arm export CROSS_COMPILE=arm-linux-gnueabihf- export PATH=$PATH:/home/tools/mitysom-57x/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin git clone --single-branch --branch processor-sdk-u-boot-2019.01 https://support.criticallink.com/git/processor-sdk-u-boot.git cd processor-sdk-u-boot
Choosing a configuration and compiling U-Boot¶
Now that you have the source code, you can customize as needed. For most projects, you will want a custom defconfig and a custom pinmux. Example defconfigs can be found in the configs/
directory. It is recommended that you start with a similar board as a reference for your own configuration.
Using the defconfig for Critical Link's Development Board as an example, you can compile U-Boot with:
$ make distclean $ make mitysom57xx_devkit_defconfig $ make
If the build is successful, you will see MLO
and u-boot.img
files in the current directory. You can copy those to your boot media to test your new build. When U-Boot boots, it will display the build date and time. Please check this to make sure your new U-Boot files are being used.
For example, note the two dates, one for the MLO
and one for the u-boot.img
U-Boot SPL 2019.01-gf686148297-dirty (Sep 02 2020 - 00:09:29 -0400) DRA762-GP ES1.0 ABZ package no pinctrl state for default mode ** Unable to read file dra7-ipu1-fw.xem4 ** Firmware loading failed Trying to boot from MMC1 no pinctrl state for default mode Loading Environment from FAT... *** Warning - bad CRC, using default environment Loading Environment from MMC... Card did not respond to voltage select! *** Warning - No block device, using default environment U-Boot 2019.01-gf686148297-dirty (Sep 02 2020 - 00:09:29 -0400)
An example pinmux for Critical Link's development board can be found in board/cl/mitysom-57x/mux_data.h
Please contact Critical Link at info@criticallink.com if you need help with customizing your defconfig and pinmux for your application.
U-Boot Build - Yocto¶
For this option, you should have an environment setup as described in Docker build environment and Building the Yocto Root Filesystem for MitySOM-AM57X.
With this option, the general Yocto setup configures your build environment. You can compile U-Boot by running bitbake commands from your build directory.
Customize your U-Boot¶
You can customize U-Boot by pointing the U-Boot recipe to your new branch location.
In your Yocto meta layer, create a u-boot bbappend file. File name is important to match existing u-boot recipe name, as of Feb 2021 the name is below
mkdir recipes-bsp/u-boot/ vim u-boot-ti-staging_2019.01.bbappend
UBOOT_GIT_URI_mitysom-am57x = "git://support.criticallink.com/git/processor-sdk-u-boot.git" UBOOT_GIT_PROTOCOL_mitysom-am57x = "http" BRANCH_mitysom-am57x = "processor-sdk-u-boot-2019.01" SRCREV_mitysom-am57x = "${AUTOREV}"
- Point UBOOT_GIT_URI* to your repository
- Update BRANCH to match your branch
- SRCREV can be set to a specific git hash if you want to lock to a specific commit instead of letting it grab the latest in the branch.
Building U-Boot¶
Then, to build U-Boot (note that this is within the previously configured Docker environment):
user@8ec23474095b:~$ MACHINE=mitysom-am57x bitbake virtual/bootloader
If the build is successful, you will find your MLO
and u-boot.img
file in ./arago-tmp-external-arm-toolchain/deploy/images/mitysom-am57x/
