Building the Filesystem
Introduction
If you are interested in building / maintaining your own Linux distribution from source for the MitySOM-A10S family, there is a Yocto compatible meta layer for the module provided at our git-web viewer: gitweb
The current branch of the Critical Link SOCFPGA is: zeus.
The recommend Operating System for the build machine: Ubuntu 18.04
Repository
Description Repository Branch Web Viewer
Critical Link MitySOM-A10S/MitySOM-5CSx meta layer git://support.criticallink.com/home/git/meta-cl-socfpga.git zeus gitweb
Development Kit Pre-built Outputs
Description Link
Development Kit Filesystem Archive mitysom-image-base-mitysom-a10s.tar.gz
Development Kit Filesystem SDK poky-glibc-x86_64-mitysom-image-base-cortexa9hf-neon-mitysom-a10s-toolchain-3.0.4.sh
Development Kit Filesystem Sources Please contact Critical Link
Development Kit Filesystem Licenses Please contact Critical Link
Setting up the Build Environment
In order to build the filesystem is recommended to use Ubuntu 18.04 LTS with the following packages installed:
docker pull crops/poky:ubuntu-18.04
Setting up Yocto
  1. Open a terminal
  2. Clone all the needed repositories
    git clone -b zeus git://git.yoctoproject.org/poky
    cd poky
    git clone -b zeus git://git.openembedded.org/meta-openembedded
    git clone -b zeus git://support.criticallink.com/home/git/meta-cl-socfpga.git
  3. Launch the docker container interactively:
    docker run --rm -it -v `pwd`:/work --workdir=/work --tmpfs /opt/poky crops/poky:ubuntu-18.04 /bin/bash
  4. You should be inside a bash shell of the docker contain. Source the yocto environment
    . ./oe-init-build-env
  5. Copy the Critical Link's Example configuration files into the build/conf
    cp ../meta-cl-socfpga/conf/bblayers.conf.sample conf/bblayers.conf
    cp ../meta-cl-socfpga/conf/local.conf.a10 conf/local.conf
Performing the Yocto Build
The following steps will build the filesystem that is used on the Critical Link MitySOM-A10S development kit.
  1. Stay inside the docker container from the previous step, or if you have exited relaunch the container in the poky folder:
  2. Source the yocto environment
  3. Build the filesystem
    bitbake mitysom-image-base
Outputs
Description Location
Filesystem Tarball <Yocto Directory>/build/tmp/deploy/images/mitysom-a10s/mitysom-image-base-mitysom-a10s.tar.gz
Build the SDK
The following steps will build the SDK with the cross-compiler toolchain that is used on the Critical Link MitySOM-A10S development kit.
Outputs
Filesystem Tarball <Yocto Directory>/build/tmp/deploy/sdk/poky-glibc-x86_64-mitysom-image-base-cortexa9hf-neon-toolchain-2.4.3.sh
Further Reading
