Linux Kernel¶
Repository:- git://support.criticallink.com/home/git/linux-socfpga.git
- https://support.criticallink.com/git/linux-socfpga.git
- socfpga-4.9.78-ltsi
- mitysom_a10s_defconfig
- mitysom_a10s_devkit.dts
The following steps will recreate the kernel and device tree for the MitySOM-A10S development kit. This will use the yocto SDK that is provided on the files section. Please note that the kernel and dtb will normally be built through the yocto build but the steps here are provided for development.
- Source the yocto SDK
source /opt/poky/2.4.3/environment-setup-cortexa9hf-neon-poky-linux-gnueabi
- Checkout the kernel source
git clone https://support.criticallink.com/git/linux-socfpga.git -b socfpga-4.9.78-ltsi
- Change into the kernel source
cd linux-socfpga
- Set the defconfig
make ARCH=arm CROSS_COMPILE=arm-poky-linux-gnueabi- -j8 mitysom_a10s_defconfig
- Build the kernel
make ARCH=arm CROSS_COMPILE=arm-poky-linux-gnueabi- -j8 zImage
- Build the device tree
make ARCH=arm CROSS_COMPILE=arm-poky-linux-gnueabi- -j8 dtbs
