MitySOM-A10S Development Virtual Machine¶
VM Info¶
A pre-configured 64-bit Ubuntu 16.04 virtual machine is provided here: https://support.criticallink.com/files/annon/MitySOM-A10S.ova (filename: MitySOM-A10S.ova — MD5 checksum: e84930821a45e2706ece48b59c84e1d0)
- Username: user
- Password: user
- Maximum storage: 200 GB
- The hard disk is dynamically allocated so it will grow as storage is needed. The base import's hard disk is ~11 GB.
- RAM: 4 GB
- CPU cores: 1
Importing the VM using VirtualBox¶
- In VirtualBox, select the menu option File -> Import Appliance...
- Click the folder icon to browse to and select the downloaded ova file, then click Next
- You can change several VM options at this stage:
- Ensure the "Reinitialize the MAC address of all network cards" checkbox at the bottom of the window is checked
- You can rename the VM if desired
- You can increase the number of CPU cores available to the VM (recommended to increase to the number available on your PC)
- You can increase the amount of RAM available to the VM (it's configured with the minimum 4 GB necessary for development, so you may want to increase it if you have enough on your PC)
- Click Import
Using the VM¶
The Linux toolchain for development is installed at /opt/poky/2.4.3/
The prerequisite packages necessary to perform a Yocto build and to build an SD card image are also installed.
Repositories¶
- The git repositories necessary for a Yocto build are cloned (all on the
rockobranch) in ~/poky/ - The Linux kernel source is cloned (on the
socfpga-4.9.78-ltsibranch) in ~/linux-socfpga/ - The Quartus example project is cloned (on the
masterbranch) in ~/mitysom-a10s/
