This page has details and links to pre-built images below.
Please refer to Building and Customizing qcom-multimedia-image with Yocto for details on building from source.
Pre-built Images
BSP Release 1.0
Initial release of qcom-multimedia-image with support for:
  • DisplayPort
  • MIPI Camera Waveshare OV9281-120 Mono Camera on CSI0
  • GPIO Control of Expansion Header pins
  • Wi-Fi Silex SX-PCEAX-M2
  • Push Button Events
  • PCIe Gen 3 2-lane
  • eMMC at HS200
  • microSD Card
SDK Toolchain
File System Image
BSP Release 1.1
Changes:
  • Audio
  • UFS Gear 4
  • evtest
  • Home Push Button
  • Add support for all CSI1-CSI4 camera inputs
  • USB C DP support on rev4 dev boards
  • Remove gpio-reserved-ranges = <48 4>;
    • This was blocking use of QUP_1 SE4 (e.g. uart12/i2c12/spi12)
  • Expanded number of QUP UARTs that can be instantiated
    • Was previously limited to 4
  • Add IMAGE_INSTALL to /etc/buildinfo so we know what packages are included
  • Added files to re-provision UFS
    • Allows for disabling write booster buffer
    • Allows for changing LUNs to be in pSLC mode
BSP 1.1 Download
  • Contains files for re-provisioning UFS
  • Contains file for programming CDT
  • Contains qcom-multimedia-image files for programming File System
  • Contains SDK Toolchain for cross compiling
BSP 1.1 md5sum
BSP Release 1.2
Changes:
  • DDR will now run at full speed (requires MitySOM-QC rev4 or greater)
  • eMMC now functions at HS400 (requires MitySOM-QC rev4 or greater)
BSP 1.2 Download
BSP 1.2 md5sum
BSP Release 2.0 (WIP)
Changes:
  • Support Qualcomm Linux 2.0 (QLI 2.0)
    • Transition from Yocto scarthgap to wrynose
    • Use kas instead of repo
