Booting from OSPI / QSPI¶
- Booting from OSPI / QSPI
See Boot_options for more details about the boot select pins
*NOTE: The XSPI boot mode can auto detect and boot the OSPI/QSPI NOR
XSPI Boot Mode for OSPI/QSPI¶
To boot the Dev Kit from OSPI/QSPI using a CL supplied image, set the boot pins as follows:
| B3 | B4 | B5 | B6 | B7 | B8 | B9 | |
| 0 | 1 | 1 | 1 | Mode (0) | ReadCmd (0) | SFDP (1) |
Steps¶
- boot to linux (i.e. from SD card).
- Check that the spi nor was detected
Make note of the mtd# for tiboot3/tispl/u-boot as newer kernels are changing up the order...root@mitysom-am62x:~# cat /proc/mtd dev: size erasesize name mtd0: 00080000 00020000 "ospi.tiboot3" mtd1: 00200000 00020000 "ospi.tispl" mtd2: 00400000 00020000 "ospi.u-boot" mtd3: 00040000 00020000 "ospi.env" mtd4: 00040000 00020000 "ospi.env.backup" mtd5: 0f7c0000 00020000 "ospi.rootfs" mtd6: 00040000 00020000 "ospi.phypattern"
- cd to boot partition (the directory containing tibot3.bin, etc.../run/media/mmcblk1p1 in my case.)
- Erase the NOR partitions
root@mitysom-am62x:~# flash_erase /dev/mtd0 0 0 root@mitysom-am62x:~# flash_erase /dev/mtd1 0 0 root@mitysom-am62x:~# flash_erase /dev/mtd2 0 0
- copy the boot files to their respective locations in SPI NOR
root@mitysom-am62x:~# cp tiboot3.bin /dev/mtd0 root@mitysom-am62x:~# cp tispl.bin /dev/mtd1 root@mitysom-am62x:~# cp u-boot.img /dev/mtd2
0x0 +----------------------------+
| ospi.tiboot3(512k) |
0x80000 +----------------------------+
| ospi.tispl(2m) |
0x280000 +----------------------------+
| ospi.u-boot(4m) |
0x680000 +----------------------------+
| ospi.env(128k) |
0x6c0000 +----------------------------+
| ospi.env.backup(128k) |
0x740000 +----------------------------+
| padding (768k) |
0x800000 +----------------------------+
| ospi.rootfs(ubifs) |
0xffc0000 +----------------------------+
| ospi.phypattern (256k) |
Flashing in u-boot from sdcard¶
sf update command erases before writing data
=> mmc rescan => sf probe SF: Detected mt35xu02g with page size 256 Bytes, erase size 128 KiB, total 256 MiB => sf update $loadaddr 0x0 $filesize device 0 offset 0x0, size 0x4e172 319858 bytes written, 0 bytes skipped in 0.880s, speed 370933 B/s => fatload mmc 1 $loadaddr tispl.bin 1554491 bytes read in 68 ms (21.8 MiB/s) => sf update $loadaddr 0x80000 $filesize device 0 offset 0x80000, size 0x17b83b 1554491 bytes written, 0 bytes skipped in 3.735s, speed 425842 B/s => fatload mmc 1 $loadaddr u-boot.img 1159387 bytes read in 51 ms (21.7 MiB/s) => sf update $loadaddr 0x280000 $filesize device 0 offset 0x280000, size 0x11b0db 1159387 bytes written, 0 bytes skipped in 2.803s, speed 423097 B/s
