Example Using USB Type A Host Ports¶
Objective¶
The goal of this wiki page is to verify that the two USB Type-A ports, connected to a USB 2.0 HUB controller, on the Devkit are working.
Prerequisites¶
- This test verifies the ports by using a USB-stick.
Steps¶
- List the usb devices when nothing is plugged in.
root@mitysom-am62x:~# lsusb Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 002: ID 0451:8027 Texas Instruments, Inc. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub root@mitysom-am62x:~#
 - Plug a USB-stick into one of the 2 USB-2.0 Type-A
ports. Use lsusb to verify that an additional device is now present.root@mitysom-am62x:~# lsusb Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 004: ID 0781:5567 SanDisk Corp. Cruzer Blade Bus 001 Device 002: ID 0451:8027 Texas Instruments, Inc. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub root@mitysom-am62x:~#
 - The linux kernel will automount USB Sticks when they are plugged in as a "SCSI" device (/dev/sda)  To locate the mount point, run the following:
root@mitysom-am62x:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 1 7.3G 0 disk /run/media/sda mtdblock0 31:0 0 512K 0 disk mtdblock1 31:1 0 2M 0 disk mtdblock2 31:2 0 4M 0 disk mtdblock3 31:3 0 256K 0 disk mtdblock4 31:4 0 256K 0 disk mtdblock5 31:5 0 247.8M 0 disk mtdblock6 31:6 0 256K 0 disk mmcblk0 179:0 0 59.3G 0 disk `-mmcblk0p1 179:1 0 59.3G 0 part /run/media/mmcblk0p1 mmcblk0boot0 179:32 0 31.5M 1 disk mmcblk0boot1 179:64 0 31.5M 1 disk mmcblk1 179:96 0 14.9G 0 disk |-mmcblk1p1 179:97 0 132.6M 0 part /media/mmcblk1p1 `-mmcblk1p2 179:98 0 3.3G 0 part / root@mitysom-am62x:~# ls /run/media/sda lost+found randFileUSB10k random_usb1.bin root@mitysom-am62x:~#
 - Before removing the USB stick you should do the following:
eject /dev/sda
 - After doing the eject, you can remove the USB stick and insert it into another port.
- The lsusb may list the USB stick with a different Device
 - The file system will likely be mounted on the same /dev/sda and be available at /run/media/sda
 - Again, do an eject /dev/sda before removing the USB stick.
 - Note: if the USB stick includes a partition table, you may see the filesystem mounted as /run/media/sda1, such as the following:
root@mitysom-am62x:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 1 14.7G 1 disk `-sda1 8:1 1 14.7G 1 part /run/media/sda1 mtdblock0 31:0 0 512K 0 disk mtdblock1 31:1 0 2M 0 disk mtdblock2 31:2 0 4M 0 disk mtdblock3 31:3 0 256K 0 disk mtdblock4 31:4 0 256K 0 disk mtdblock5 31:5 0 247.8M 0 disk mtdblock6 31:6 0 256K 0 disk mmcblk0 179:0 0 59.3G 0 disk `-mmcblk0p1 179:1 0 59.3G 0 part /run/media/mmcblk0p1 mmcblk0boot0 179:32 0 31.5M 1 disk mmcblk0boot1 179:64 0 31.5M 1 disk mmcblk1 179:96 0 14.9G 0 disk |-mmcblk1p1 179:97 0 132.6M 0 part /media/mmcblk1p1 `-mmcblk1p2 179:98 0 3.3G 0 part / root@mitysom-am62x:~#
 - You can try each port to verify that the USB stick is usable regardless of which port is used.
Conclusion¶
The steps needed to verify the USB-2.0 Type-A Hub ports are shown.
