Getting Started¶
This page provides links to information about getting start using the MitySOM-AM62 or MitySOM-AM62A and Development kit.
Unless specifically noted, the examples below should apply to both the MitySOM-AM62 or the MitySOM-AM62A.
Initial Hands-on Examples | |
Serial Console | This example connects the Development Kit Console port to a host system, powers up the development kit, and provides basic verification that the development kit is working. |
Uart2 Serial Console | This example creates a serial connection from the SOM to your host system via uart2. |
Hello World | This example creates and runs a simple Hello World program on the ARM processor of the development kit. |
1 Gb Ethernet | This example connects and verifies the basic operation of the 1 Gb Ethernet link. |
Reading Temperature and Power Monitors | This example demonstrates how to read the CPU temperature and SOM power monitor. |
Setting SOM Clock Speed | This example demonstrates how to read and control the SOM Cortex A-53 Clock speeds in linux. |
Leds | This example demonstrates how to control the different LEDs in linux. |
Cortex-A53 Peripherals | |
USB A ports | This example demonstrates the use of the USB 2.0 Host ports with the Development Kit. |
HDMI | This example demonstrates the use of an hdmi display with the Development Kit. |
Audio | This example demonstrates the use of the audio in and audio out ports |
SOM OSPI NOR | This example provides information on how to use the SOM OSPI NOR on the Development Kit. |
SOM eMMC | This example provides information on how to use the SOM eMMC on the Development Kit. |
RNDIS setup | This example provides information on how to setup RNDIS on the Development Kit Dual Role Port. |
Accessing a GPIO pin | This example provides information on how to access a GPIO pin from the command line. |
USB 2 Dual Role | How to use the USB 2.0 dual role port in both roles |
CSI2 Camera Capture | Example to capture from MIPI/CSI-2 camera module |
TI WL1837 WIFI/BT Module | How to use Wifi/BT with the WL1837 module |
MCU CAN Access from Cortex A-53 | |
Accessing MCU CAN ports from Cortex A-53 | Information to use MCU MCAN ports on DevKit with A-53 core |
Edge AI Examples (MitySOM-AM62A Only) | |
AM62Ax Edge AI Examples | Information on running the TI supplied Edge AI Demos |
MCUSS Peripherals (MitySOM-AM62 Only) | |
MCU CAN Interfaces | Information and examples on using the MCU MCAN interface from the M4 |
PRUSS Peripherals (MitySOM-AM62 Only) | |
Startup Related | |
boot options | How to configure different boot modes for the module |
