Wiki Map
Pages with TODO tag
Pages with REVIEW tag
TI WL1837 Wifi/Bluetooth Module
The MitySOM-AM62x Dev Kit supports the TI WL1837 Wilink Wifi/Bluetooth module. The module can be installed in slot J14 on the bottom side of the dev kit.
https://www.ti.com/product/WL1837MOD
Once installed, you will have to enable the device tree overlay for the module.
In u-boot
=> setenv name_overlays k3-am62x-mitysom-sdhci2-wl1837.dtbo
=> boot
The module is directly supported by the filesystem shipped with the dev kit. No further configuration is necessary.
To make the confiugration permanent, add the following line to the uEnv.txt file (found in /run/media/boot-mmcblk1p1/uEnv.txt on the CL provided filesystem)
name_overlays=k3-am62x-mitysom-sdhci2-wl1837.dtbo
Wifi Software Configuration
TI provides module configuration scripts for initializing the Wifi Module. After logging in, run the following commands
# /usr/share/wl18xx/sta_start.sh
# iw wlan0 scan |grep 'SSID: [^ ]'|sort -u
This will scan for visible SSIDs.
Note: If you get a Failed to read or parse configuration '/usr/share/wl18xx/wpa_supplicant.conf' due to p2p lines, simply comment those lines out in the wpa_supplicant.conf file and rerun the start script.
Once you know the network you'd like to connect to, you can connect to it using:
# /usr/share/wl18xx/sta_connect-ex.sh "yourSSID" WPA-PSK  SECRETPASSWORD
where "yourSSID" is your desired SSID and SECRETPASSWORD is the access point password.
Once connected, you should be able to communicate with other devices on the network.
Wifi Testing
You can find your link speed and other connection parameters using:
root@mitysom-am62x:~# iw dev wlan0 link
Connected to 02:92:bf:58:cb:77 (on wlan0)
        SSID: criticallink-5G
        freq: 5180
        RX: 48338470 bytes (371097 packets)
        TX: 515134776 bytes (334460 packets)
        signal: -53 dBm
        rx bitrate: 65.0 MBit/s MCS 7
        tx bitrate: 135.0 MBit/s MCS 7 40MHz
        bss flags:      short-slot-time
        dtim period:    3
        beacon int:     100
We recommend using iperf3, included in the dev kit filesystem, for testing your network throughput.
